What is
Old Feb 10, 2012 | 08:34 PM
glassman74's Avatar
glassman74
Default What is
The correct way to change the alternator?? Thanks glassman74
Old Feb 10, 2012 | 09:00 PM
sfc rick's Avatar
sfc rick
Disconnect the battery cables, then take a 15mm deep socket and ratchet and push the belt tensioner pulley to take the belt off the tensioner pulley. walk around to the altenator side and take the loose belt from the alt. pulley and pay attention to the belt routing.
Then take the positive cable off the backof the altenator with a 10mm wrench. Unplug the wiring harness connector also from the rear of the altenator.
Once all the wiring has been removed, take a 15mm wrench and remove both bolts holding the altenator to the altenator bracket then remove the altenator!
You are done.
Old Feb 10, 2012 | 09:10 PM
glassman74's Avatar
glassman74
Thanks Rick. How many amp's should the alt. put out?? glassman74
Old Feb 11, 2012 | 08:37 AM
sfc rick's Avatar
sfc rick
Originally Posted by glassman74
thanks rick. How many amp's should the alt. Put out?? Glassman74
110
To What is
