Any problems: 17x8.5 front and 19x10 rear c5
Are there any problems with running the 17x8.5 wheels up front and 19x10 rear on a 2004 c5?
Thanks,
larry
Thanks,
larry
it ain't about wheel size, it's about tire height. if you pick the appropriate tire sizes that ensure the overall diameter don't change much, you'll be fine. the wheel size shouldn't be a factor unless you're using bigger brakes.
