New radiator
Old Feb 16, 2012 | 03:46 PM
Lear31A's Avatar
Lear31A
Default New radiator
My radiator has a small crack on the top passenger side and is leaking! Aftermarket or stock is the question here, also, how difficult of a job will this be? Who do you recommend buying from? Its a bone stock 1998 C5.Thanks
Old Feb 16, 2012 | 05:59 PM
robert miller's Avatar
robert miller
Post up in here in the sale and buy section,you want to buy a used one in here. I just sold one last year out of my car. Robert
Old Feb 16, 2012 | 06:50 PM
NatB's Avatar
NatB
If you plan to keep the car, I would recommend going with a new stock GM replacement radiator.
If you are replacing the original on your 1998 , the performance is proven.
Old Feb 16, 2012 | 06:58 PM
Big_George_S's Avatar
Big_George_S
I just did a search on radiator replacment and ran into www.radiator.com might want to check them out will probably save you money over the stealer.
Old Feb 16, 2012 | 08:18 PM
Lear31A's Avatar
Lear31A
Thanks guys, this gm radiator has lasted 14 years. Guess I will stick to the oem part.... I just had the front main seal replaced, wonder if the radiator is just coincidence? Is it possible that they cracked my radiator? Did they have to remove it? Anywho, thanks guys
Old Feb 16, 2012 | 08:24 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
It's an easy job.
Get a used one from the for sale section here.
Old Feb 16, 2012 | 08:26 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
While technically I suppose you could replace the front seal without removing the radiator, it is highly likely that it was removed for that repair.
Old Feb 16, 2012 | 08:42 PM
Paul 75 L82's Avatar
Paul 75 L82
I would never buy a used radiator. The water passages on the lower part of the rad get filled with crud, I always buy new rad. Nothing wrong with the stock part.
Old Feb 22, 2012 | 09:25 AM
Lear31A's Avatar
Lear31A
I bought a new radiator and replaced it myself. Very easy job using the drive up rhino ramps. I spent more time cleaning everything under there than I did removing and replacing the radiator. I am not a mechanic by any stretch of the imagination either. Labor cost would have been $250 and the dealership and $150 at the local shop. Thanks for the advice!
To New radiator
