raptor shift light help
Old Feb 16, 2012 | 10:25 PM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
Default raptor shift light help
So, i found the right tach wire because i cut in in half accidentaly. Lol. So after that mess i hooked it up. Lights on the shift light flash correctly. I have it set to 3100 to test it. And nothing. Obviously i have all 3 wires right. Anyone run into this?
Old Feb 16, 2012 | 11:20 PM
bumble-z's Avatar
bumble-z
Your Raptor a single or dual stage.?
Another words is your light capable of setting both the launch & shift points too? Dual settings
Are you sure the movable switch sliders are set correctly?
They should be set for 4 cyl mode .
#1 slider. Downward away from "ON"
#2 slider. Upward towards "ON"
#3 slider. Downward away from "ON"
Old Feb 16, 2012 | 11:22 PM
VGLNTE1's Avatar
VGLNTE1
Nope
Old Feb 17, 2012 | 06:17 PM
bumble-z's Avatar
bumble-z
Originally Posted by VGLNTE1
Nope
So.... What did you find out, or did you?
Old Feb 17, 2012 | 06:29 PM
LSOHOLIC's Avatar
LSOHOLIC
http://forums.corvetteforum.com/c5-t...e-install.html
Complete install....not sure if it will help. Good luck
Thanks.....
To raptor shift light help
