Power Steering Pulley
Old Feb 18, 2012 | 12:12 PM
o1Z0sick's Avatar
o1Z0sick
Default Power Steering Pulley
I am looking for the power steering pulley that has slots or star pattern. I have seen a few of these out there but which is the correct one? Preferably the polished one if available. Would any of these work? http://www.krcpower.com/catalog_c353637.html
Old Feb 19, 2012 | 02:27 AM
Last C5's Avatar
Last C5
Ecklers and Zip Product both carry a billet spoked power steering pulley for the C5. Not all LS1 pulleys will work on the Vette as it has a different offset than the LS motor in the Camaro.
Old Feb 19, 2012 | 09:25 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I think I heard that the LS2 pulley will work on the LS1 and has holes. Not polished of course.
Old Feb 19, 2012 | 02:55 PM
BaadGoat2006's Avatar
BaadGoat2006
the alum pullies are a pita. I have installed a few and they ALL have squeaked. Changed belts, used dressing. It was enough to where we went back with the plastic pulley. Not worth the work to change imo.
Old Feb 19, 2012 | 03:54 PM
LoneStarFRC's Avatar
LoneStarFRC
True story. Have been using one for several years. No issues whatsoever. GM part #12568997 Cheaper than the PITA plastic pulley too.
If you want bling you can have it powder coated or chromed if you like.
HTH
Old Feb 19, 2012 | 10:13 PM
o1Z0sick's Avatar
o1Z0sick
Thanks for the tips. I ended up ordering the pulley for the LS2, LS3 vette. $27 bucks shipped to my door, so that's about $70 cash back in my pocket from the aluminum piece. The LS2,LS3 is only 0.3" different in diameter than the LS1,LS6 which is not at all a problem.
The whole reason I need a new pulley is that the hub lip broke and the tool could no longer pull on that. Ended up greanading the plastic because I drilled and taped to use a three bolt puller. Once the hub was exposed I could use the lip the plastic was molded into to remove rest of steel hub.
This is going to make life a lot easier re-installing the flip drive.
To Power Steering Pulley
