Changing c5 lights????
Old May 14, 2002 | 03:48 PM
thegame's Avatar
thegame
Default Changing c5 lights????
Hey guys whats up what is the easiest way to change the headlights bulbs, the highbeams and lowbeams thankz............ :seeya
Old May 14, 2002 | 04:07 PM
DJTJ's Avatar
DJTJ
Default Re: Changing c5 lights???? (thegame)
I turned on the lights, then turned them off (so the bulbs are off, but the headlights are still up) and stuck my hand in and swaped them. Fairly simple. Took a little twisting and turning, but seemed to work fine :D
Old May 14, 2002 | 11:05 PM
c5 Lee's Avatar
c5 Lee
Default Re: Changing c5 lights???? (DJTJ)
Man I did not think of that. I spun the manual opener to raise mine.
The install is pretty straight forward. Just make sure that all of the tabs are in place before you twist to install. You will see what I am talking about. If not the lights will be out of adjustment.
Lee
To Changing c5 lights????
