90k Maintenance
Old Feb 19, 2012 | 09:28 AM
msp1055's Avatar
msp1055
Default 90k Maintenance
Just got a used 90k c5, it appears to run good, however I want to know that if I decide to push it that it will be there and not fail. Not sure of the history, so what should be done besides the obvious, oil, plugs, filter.
Old Feb 19, 2012 | 11:08 AM
jrose7004's Avatar
jrose7004
Fluid change, check the brakes, filters etc.
Old Feb 19, 2012 | 03:56 PM
jcgunn's Avatar
jcgunn
ALL fluids, belts, hoses, plug wires, fuel filter, maybe O2 sensors. TPMS at next tire change if they are original...and it probably needs shocks, a great time to upgrade to C6Z or Bilsteins, etc
Old Feb 22, 2012 | 03:19 PM
msp1055's Avatar
msp1055
Thanks,,
Old Feb 22, 2012 | 04:07 PM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
It's a good idea to change out the plugs because they tend to be really tight after some miles...Mine were bears to remove after 65K. Some anti-seize might be in order on the new ones. !
Old Feb 27, 2012 | 04:59 PM
msp1055's Avatar
msp1055
Thanks,, good idea
Old Feb 27, 2012 | 05:09 PM
Paul Wood's Avatar
Paul Wood
Is it an A4 or M6? If M6 then clutch fluid for sure in addition to the above. If A4 fluid and filter. Good Luck
Old Feb 27, 2012 | 08:09 PM
msp1055's Avatar
msp1055
A4, thanks,,,
To 90k Maintenance
