Steering rack removal help
Old Feb 19, 2012 | 06:11 PM
vettegirl925's Avatar
vettegirl925
Default Steering rack removal help
Whats the easiest way to get the steering rack out? Trying to twist and turn to get it to come out either through top or one of the wheel well sides but not having any luck. Am i going to have to piece it out? Advice please
Old Feb 19, 2012 | 06:19 PM
IBSR z06's Avatar
IBSR z06
When I took mine out. I found I got the most room by taking off one of the hard lines on the rack (the 16mm one), disconnecting the sway bar and loosening the front subframe bolts and lowering the subframe down alittle, to gain more clearance. By doing that I was able to get it out by pulling it out of the driverside. It did take some turning and twisting still though.
Old Feb 19, 2012 | 06:42 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I'm curious...are you removing the rack due to rack problems, or to take care of an issue with the engine's balancer?
Old Feb 19, 2012 | 07:12 PM
vettegirl925
Was able to get it out through the top by removing the waterpump for more clearance! Thanks
Old Feb 19, 2012 | 08:47 PM
Paul 75 L82's Avatar
Paul 75 L82
Lift it up where it's out of the frame then roll it forward where the steering box is in front. Then take it part way out of the passenger side well till you can drop the drivers side down below the frame then remove it out thru the drivers side.
Old Feb 19, 2012 | 09:21 PM
vsocks1's Avatar
vsocks1
Old Feb 19, 2012 | 09:28 PM
m6 c5's Avatar
m6 c5
That sounds a lot easier than what I did, I managed to get mine out through the drivers side wheel well without droping it down below the frame or anything. I think I had to turn it at least 720* but I finally got it out, put it in the same way too. I think the opening is actually smaller than the box..
Old Feb 20, 2012 | 12:22 AM
CatCam's Avatar
CatCam
Vettegirl -
I read your other post -- did you pull your oil filter? A lot of more seasoned folks said you should check it.....
BTW - pretty impressed that you ain't scared to fix it yourself!!
Good Luck!
To Steering rack removal help
