Clutch Problems
Old Feb 19, 2012 | 06:15 PM
Blackcloud 1's Avatar
Blackcloud 1
Default Clutch Problems
Just had cam installed.When I drive the car easy I have no problem,but when I run hard the clutch peddle has felt hard to press down,and has stayed down on the floor.What is going on.
Old Feb 20, 2012 | 11:42 AM
SaberD's Avatar
SaberD
you need to bleed your clutch fluid. if that doesnt do the trick, you need a new slave cylinder.
Old Feb 20, 2012 | 01:21 PM
Blackcloud 1
thanks for the info,I found a post that sent me to Rangeracceleration.com I will try this method,my fluid is very dirty.
Old Feb 21, 2012 | 11:53 AM
liquidforce917's Avatar
liquidforce917
I had this same problem. my fluid was dirty due to the PO and whenever i would drive it hard my clutch pedal would stick half way up or not come up at all!
so i did this method and the problem has subsided but will still come about when i do a longer period of hard driving. The only real fix that i have found through research is to replace the slave cylinder, but its a PIA from what i have heard.
Also it takes multiple times of the RANGER method to change the fluid completely. good luck and i hope this helps
Old Feb 22, 2012 | 03:00 AM
Blackcloud 1
Thank you for your reply !!!!!
To Clutch Problems
