Old Feb 23, 2012 | 11:58 AM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
Default 2860
could someone help me . I can't seem to get the search to work.
the telescoping steering wheel doesn't work and I got this code.
a6 scm 2860h. thanks Jim
Old Feb 23, 2012 | 01:58 PM
Turbopower87's Avatar
Turbopower87
It is a history code and not current so clear it out and see if it comes back.
Do you hear the motor trying to move when you press the button? Mine had gotten to where it would not telescope all the way out but still moved below that point. I read where you could do a sequence of inputs and it would relearn the position however I don't know if that is actualy true. That didn't fix my problem but after tapping it outward about 10 times it started working again. It worked great for awhile and then just the other day it got stuck again but tapping it a few times fixed it. I'd start with that and if not here is the first thing that came up when I googled it http://www.corvetteactioncenter.com/...r-failure.html
Old Feb 23, 2012 | 05:40 PM
JBrooke825's Avatar
JBrooke825
mine doesn't work at all. if you push the toggle in toward the dash
about 10 times you can here the relay under the seat click. you hear
nothing the other way. I checked the blue connector under the seat.
it looks good. maybe I should take out the seat and look under there.
I can't seem to get the bolster off . is it screwed on under the other
dash panels. I had one off a couple of years ago .I just can't seem to remember.
To 2860
