I just finished getting the transmission back in the car with a Yank 3600 Stall tc. Anyways, I already purchased the cam (Torquer V2 on a 112 lsa) and now that I'm ready to begin the swap I need to clear a few things up.
1st, do I need new lifters? I know I can use the stock ones, but is it gonna hurt anything in the long run?
2nd, Assuming I can use the stock lifters safely, what push-rods would y'all recommend for that cam? Valve Springs? (.595 Intake & .598 Exhaust).
And 3rd, When upgrading the timing chain, do I just go with an ls6 timing chain? Or do I need an ls6 sprocket too, if they are different from the ls1?
Unlike flat tappet lifters, the roller lifters in the LS engines do not develop a wear pattern specific to each lifter/cam lobe, so they are reusable. If you want to replace the lifters you have to pull the heads.
Pushrod length depends on the base circle of the new cam compared to the oem cam. Best bet is to measure for correct length once the cam is in.
I think the LS2 chain is the oem chain of choice now.
Reuse your lifters, I used the LS2 chain and used the cam sprocket but I didn't want to pull the crank sprocket so I just used the stock crank sprocket. There's a good chance that 7.4" pushrods will work, they did on mine but that doesn't mean that they will work for you. Buy the Hawk Balancer Installation tool, it's well worth the money. I used the Ridgid strap wrench to hold the balancer when I torqued the new ARP crank bolt. That baby takes more tourque than any bolt in the world.
I would get an adjustable push rod and measure it. I forget what I used, but it was something a bit less than 7.4 on 5.3 head. I can't say for sure if the LS7 lifter was a direct swap or not. It was close, but I did heads/cam/roller rockers all at once, so I can't tell what made the slight change.
