Check engine light - codes- help
Old May 15, 2002 | 12:49 AM
Paradigm's Avatar
Paradigm
Default Check engine light - codes- help
Got 1384 - 1571 - 1626 -
All had H - history
I looked them up but can't find the 1384 and what does 1571 mean? I understand 1626.
Old May 15, 2002 | 01:12 PM
weaver's Avatar
weaver
Default Re: Check engine light - codes- help (Paradigm)
I can't find 1384 either; are you sure it's not 1381?
P1571, ASR Desired Torque Circuit, from Alldata:
The PCM supplies 5.0 volts on the Desired Torque circuit to the Electronic Brake and Traction Control Module (EBTCM). The EBTCM toggles this 5.0 volt signal to a ground in order to produce a duty cycle signal. The signal is proportional to the amount of engine output torque reduction requested by the EBTCM. The EBTCM supplies this signal when it detects a wheel slip. In order to reduce engine output torque the PCM reduces the amount of spark advance and in some cases the PCM disables a number of fuel injectors. This diagnostic test checks for a Desired Torque signal failure. If the PCM does not receive the Desired torque signal this DTC sets.
Old May 15, 2002 | 08:49 PM
RadarBlue's Avatar
RadarBlue
What is/are the letters in front of the numbers? S/b "B" "C" "P" or "U"...
Also, what year is your car? There are diferences between years.
To Check engine light - codes- help
