Cartek vs RSD line lock?
Old Feb 26, 2012 | 08:09 PM
airbrush1's Avatar
airbrush1
Default Cartek vs RSD line lock?
I'm going to place an order for a line lock tomorrow morning... I'm debating between these two, and I'd like some insight into the differences and advantages/disadvantages of each unit.
The manufacturers can feel free to chime in here as well, as I haven't seen a comparison done between the two units.
Old Feb 26, 2012 | 08:36 PM
Pete W's Avatar
Pete W
I am going to be interested in this, as well. I am going to be going to the track more this year, so I think I will need one.
Old Feb 26, 2012 | 09:33 PM
evo2ls1's Avatar
evo2ls1
Dont know anything about the rsd but the cartek is great and has never failed, had it for a few years now, and had prebent lines just bolted in.
Old Feb 26, 2012 | 10:15 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Old Feb 27, 2012 | 12:15 AM
bumble-z's Avatar
bumble-z
I think the RSD (Race Specialty Design) is the best designed & easiest to install of them all.
There are no hard lines to contend with & the solonoid hangs nicely off the two bolts of the brake resevoire bolts.
In stead of mounting a switch or button in the car, I ran the two wires
with a male & female terminals & keep them tucked & out of sight under the drivers side console area (down by your right leg)
I keep a "stretchable lined thumb switch" with a matching male & female terminals on it, inside the console compartment.
When I'm ready to use the line loc, I pull the wires down a tad from the area by your right leg, take the flex lined switch out of the console compartment & attach the terminals together.
When connected, just close the console lid on the flex line close to the switch thumb button & it's right there near your right hand & shifter.
Ready, set, go!!
Switch looks Looks likes this.
Check out rsd's line loc unit on their site & you'll see what I mean
about how nice a unit it is.
http://www.racespecialtydesigns.com/...p?productid=46
Old Feb 27, 2012 | 09:21 AM
Chicago1's Avatar
Chicago1
Old Feb 27, 2012 | 09:47 AM
jfernandez98's Avatar
jfernandez98
Default Installed RSD Line Lock
Hi,
I installed a RSD line lock last year on a 2003 Z06 with Headers. Overall nice design and came with all fittings, hoses, wires and switch. Took a couple of hours. Best advice would be to unbolt air tube and temporarily remove from header as it gave me much more room to work. RSD needs to update their directions as they were for old design and makes it somewhat confusing as new solinoid is rotated differently on bracket. Once I figured out how lines should be routed the rest was easy. I liked the fact that the hoses came with the high temp covering already in place. They also use a B&M solinoid. I mounted the switch on about 12" of wire and wrapped it so that the wire is somewhat stiff and have it in the center console. When I'm ready to use it I open the center console and pull the switch and wire up. I can then close the console cover.
Good Luck
Old Feb 27, 2012 | 10:34 AM
airbrush1's Avatar
airbrush1
good responses guys! Thank you! keep em coming!
Old Feb 27, 2012 | 10:46 AM
airbrush1's Avatar
airbrush1
Just purchased the RSD unit, I'll post my install and functionality thoughts/experiences when I install it saturday!
Old Feb 27, 2012 | 10:52 AM
Julian@Cartek's Avatar
Julian@Cartek
Thank you for considering us...the Cartek Line lock kit is the easiest kit on the market to install. Our kit comes with the lines pre-bent and solenoid inline. Its a direct replacement of the OEM line with OEM quality/appearance.
We stand behind our product, if you have any questions please give us a call and we will be more than happy to take care of you.
Thanks,
Julian
(908) 317-4496
www.cartekracing.com
To Cartek vs RSD line lock?
