need help with dual climate control
Old Feb 27, 2012 | 12:26 AM
427TTA4's Avatar
427TTA4
Default need help with dual climate control
Okay cf need your help again..I went for a night drive and looked down at my CC and nothing its completely dead no light what so ever...buttons don't work checked both relays and their good.Is their a fuse or something I'm not checking??or some kind of testing the bad part is that my daily is down for this week and I gotta freeze my but off wich sucks in the AM...Thanks for your help..
Old Feb 27, 2012 | 07:48 AM
427TTA4's Avatar
427TTA4
I checked my codes and I'm getting B0432 and on 99-HVAC it says NO COMM.
Old Feb 27, 2012 | 09:44 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I'm traveling right now so can't tell you which fuse but try looking in the passenger footwell fuse box for any hvac fuses. The one code is for the rear defrost relay circuit. Fuse 18 and 27 need to be checked.
Old Feb 27, 2012 | 11:57 PM
427TTA4's Avatar
427TTA4
Thanks ill give them a check tomorrow and see how it goes
Old Feb 28, 2012 | 08:20 AM
TOPCATHR's Avatar
TOPCATHR
Common problem do search easily fixed if you can solder............
Old Feb 28, 2012 | 08:51 PM
427TTA4's Avatar
427TTA4
Man this blows I got caught in a storm and I had to pull over for an hour because I could not see a thing
Old Feb 29, 2012 | 08:04 PM
427TTA4's Avatar
427TTA4
Found the problem #18 fuse was not making good contact just bent the fuse a little and walla lol thanks for all yall's input thanks
Old Feb 29, 2012 | 11:11 PM
dgrant3830's Avatar
dgrant3830
Excellent! Easy fixes are always the best ones to have.
To need help with dual climate control
