Re: Best way to install Amber side markers ? (Snake Slayer)
Well, I have a FRC, coupe/vert may or may not be similar. The drivers side has a cut out inside the trunk. Just pull out the cover and you can get your hand inside to remove the 2 nuts with a small ratchet. The passenger side has no cut out :confused: , so you will have to pull the rear wheel, remove most of the bolts holding the wheel well liner and reach from there. If you happen to be changing out the exhaust at the same time, you can reach up from the bottom I think.
