2000 C5 Headlight noise after closing
Old Mar 4, 2012 | 09:50 AM
vetterss's Avatar
vetterss
Default 2000 C5 Headlight noise after closing
I've searched the posts and read many of them, but want to verify what everyone thinks. My passenger headlight would not come up the other night. After several trys it did pop open. When I shut the car down for the night, the light closed alright but there was the sound of the headlight motor still running for a several seconds after it had closed. 2 questions:
-Is this the need to replace the gear issue??
-Does the entire light assembly have to be removed from the car to complete this gear or motor change if that is what you think it might be?
I appreciate any feedback, thanks!
Old Mar 4, 2012 | 09:53 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
you guessed right...
I removed the whole assembly as I know my luck if I tried to do it in the car I would drop something and end up removing it anyway
not sure if the 2000 still have the 3 screws holding the cover on like the 99's but I am sure you saw the DIY sticky in C5 tech where I and others posted the rebuild procedure and pics...
not a hard job.
Old Mar 5, 2012 | 10:34 AM
scarolina's Avatar
scarolina
Look up rodneydickman.com. he sells the gears you need to replace it for cheap and fast. had to do it to my 2000 as well.
To 2000 C5 Headlight noise after closing
