When is a headlight motor toast?
Old Mar 5, 2012 | 09:29 PM
MSUGTO's Avatar
MSUGTO
Default When is a headlight motor toast?
Good evening I've recently replaced my driver's side headlight gear, and all went well with that. However, since doing that I've noticed that the actual motor rotates a bit when compared to the housing it is attached to, the part that house the gear itself. This slack seems to allow a bit extra play in the headlight when it is raised and lowered. Does the headlight motor need to be replaced?
