Should you ALWAYS set wipe pattern?
Old Mar 9, 2012 | 12:03 PM
sean.b's Avatar
sean.b
Default Should you ALWAYS set wipe pattern?
http://forums.corvetteforum.com/c5-t...e-pattern.html
I'm reading on this now, but at the same time all of the "replace your own rockers" posts, including that on LS1howto.com, dont mention it.
I cant imagine why you wouldnt always want to do this? Is it standard that people do this, or is it above and beyond security that only some do?
Old Mar 9, 2012 | 12:36 PM
baxsom's Avatar
baxsom
from what i understand, it is only for adjustable aftermarket rockers.
Old Mar 9, 2012 | 02:23 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
that is for roller tip rockers.
stock rockers sit on the inside of the valve stem and move to the outside as it lowers. You don't have to adjust these
Old Mar 9, 2012 | 02:37 PM
sean.b's Avatar
sean.b
oooh, that makes it all make sense then. thanks.
To Should you ALWAYS set wipe pattern?
