Burning Oil
Old Mar 11, 2012 | 04:29 PM
Mathew702's Avatar
Mathew702
Default Burning Oil
Hi all,
I have a 99 c5 corvette coupe with 98k miles. Vararam b2, Kooks 1 7/8's headers with catless x-pipe, B&B Bullet quad tip exhaust. Professionally tuned about a year ago. Since then I've noticed a increase in white smoke coming from my exhaust during decel after WOT. I am currently burning oil at a rate of 1 quart per month. I had a compression test done and the results show even compression across all cylinders. I installed a oil catch can in hopes that pcv was the culprit. No luck. Does this confirm that my oil is leaking through valve guide seals? Will a valve job fix my issue? Any input is appreciated. Thanks
Old Mar 17, 2012 | 01:52 PM
Birdman's Avatar
Birdman
Mine blows smoke (leaves trail) at WOT in the lower gears, and puffs it when I step on it in the higher ones.
'01 Z, LT headers, catless x, rich tune, burns oil.
Not trying to hijack, but hopefully get more responses for yours, as well as mine, lol
Old Mar 18, 2012 | 02:09 AM
Bill Dearborn's Avatar
Bill Dearborn
White smoke is more indicative of a coolant leak into a cylinder. Burning oil will be blue to black color.
Bill
Old Mar 18, 2012 | 08:41 AM
sfc rick's Avatar
sfc rick
White is coolant, blue is oil. Park it and have someone gas it a few times while you watch it from behind and see it yourself. You could easily post a video here too.
I had puff of blue smoke on start-up and evetually saw blue smoke behind me after WOT and letting off the throttle. It WAS valve stem seals and I had them replaced and used that opportunity to have the heads worked over and milled for more horsepower.
Problem solved!
To Burning Oil
