Clutch Question
Old May 16, 2002 | 04:25 PM
GaryZ06's Avatar
GaryZ06
Default Clutch Question
Ok guys here is one for you.I was at the track last night and at the end of the quarter mile I pushed my clutch pedal down to put in nuetral and the clutch pedal was stuck about 3 inches from the floor.I stopped and tried to pull away and it still worked but had 3 inches of travel.I then took my foot and put it under the clucth and it popped right back to the normal position.This happened on the remaining 6 passes.The clutch grabs like a gorilla holding a banana.....so that part of the clutch is fine.This only happened at the track ONLY this time....never before....Thanks
