I used to run this because I liked the thickness at higher temps. I had to change to 0-40 though because the 15w was way to thick on start ups with my 3qt stand alone oil cooler. I wouldnt have pressure for a few seconds
That is way to thick of an oil to be using in these engines. At start up that stuff would be like molasses and it's even too thick at normal operating temps. Being too thick at start up is going to wear on your engine.
WHY would you do this? You a petroleum engineeer or know better than the people that built the car?
This is the worst argument ever yet it continues to pop up in so many threads.
By your logic if your not a GM engineer than you should just blindly take what they have done and assume its the best thing for the car. SO .... If I go out and get coilovers it will not improve the car because I am not an engineer, I dont know much about how dampening and spring rates effect the C5. So since I am not the people who built the car obviously know better so the car will handle worse with the coilovers.
This argument makes no sense at all, GM has recommendations based off NORMAL use of the car but not everyone drives the car the same, some track it some let it sit under a cover for 10 years and drive it 1k miles a year, some its their daily driver. There is no way you are going to have 1 oil that is best for every use.
No I am not a petroleum engineer and why would I do this because I have read here that others have done it and am curious if anyone else continues or have done it. And considering that most here are not automotive engineers then why modify cars at all.
I just asked a simple question that has been gone over before and of course the know it all come out to answer and don't add anything to the conversation.
well, I AM an engineer, and I have also tried many diff fluids in my car, so I have first hand knowledge as well. You can run this oil and it will be fine, along with 10-30, 10-40, 15-50, 0-40 and so on. They all just have different charicteristics that one may want. I road race, so I see big temps, so the 40-55 weight stuff is better. If you live in a hot climate, id run a thicker oil. Or opposite if you are in a crazy cold area. Its all in how your car reacts to it. Saying anything other than 5-30 is bad is ignorant as XXXX.
kthanxbye
well, I AM an engineer, and I have also tried many diff fluids in my car, so I have first hand knowledge as well. You can run this oil and it will be fine, along with 10-30, 10-40, 15-50, 0-40 and so on. They all just have different charicteristics that one may want. I road race, so I see big temps, so the 40-55 weight stuff is better. If you live in a hot climate, id run a thicker oil. Or opposite if you are in a crazy cold area. Its all in how your car reacts to it. Saying anything other than 5-30 is bad is ignorant as ****.
kthanxbye
Thank you. For the answer. That is exactly what I was looking for.
I really hate when people that don't you chit chime in with their answers. I bet most that give those types of answers never get their hands dirty.
Just keep in mind that if you use this oil you will want to make sure its up to temp before putting and decent power down or going into high rpm's. If your car is a daily driver I wouldnt run this until summer due to ambient temps in NY.
This really is more of a road racing type oil so if thats what you will be using it for you should be fine as long as its warmed up. I personally wouldnt use it for a daily driver or autocross car, I would go with a 40 weight for those.
I was actually thinking 10w40. But just wanted some opinions on this.
I will be running it on the road course (street also) doing Time Attack.
After reading about the oil temps in these cars getting north of 300 degrees on track I want to use the best oil possible. Redline is the best IMO.
Running on the street the engine takes no abuse at all unless you like getting tickets
Where is the (percieved) upside to this? Most engine wear happens on startup, having THIN oil on startup is ideal especially if the engine ever sees cold duty.
ok, i use 15w50 in my atv's and motorcycles becsaue they are a wet clutch of where both the engine and transmission share the same oil and energy conserving oil is hard on some clutch material. 15w50 mobil 1 is non-energy conserving oil
All 5w40, 5w50, 10w40, 15w40, 15w50, and 20w50 oils which I have found are not energy-conserving
