15w50 oil who's using it here
Old Mar 15, 2012 | 01:48 PM
racetchr's Avatar
racetchr
Originally Posted by 540 vette
How do you know it is a train wreck. Do a search on the internet and this forum. There are plenty that do it.
I meant the conversation! I already use heavier oil!
Old Mar 15, 2012 | 02:01 PM
540 vette's Avatar
540 vette
Sorry. What oil do you use and what weight.
Old Mar 15, 2012 | 02:06 PM
betelgeuse's Avatar
betelgeuse
Originally Posted by dougbfresh
Where is the (percieved) upside to this? Most engine wear happens on startup, having THIN oil on startup is ideal especially if the engine ever sees cold duty.
I think there would be less upside to running 5-30 oil on the track at 300 degrees than it would using 15-50 for a few cold starts......wouldn't you?
Greg
Old Mar 15, 2012 | 02:52 PM
racetchr's Avatar
racetchr
I use 10w-30w in the winter mos and 20w-50w summer Mobil 1.
Old Mar 15, 2012 | 04:35 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
I was actually thinking 10w40. But just wanted some opinions on this.
I think 10W-40 would be the better choice. Cold start up wear, especially in my climate, would concern me if using 15W-50.
Your mornings in Long Island are not as cold as mine, but I still would have some concerns.
Old Mar 15, 2012 | 04:47 PM
SoDiezl350's Avatar
SoDiezl350
It seems a potential solution to the risks of lack of lubrication during startup would be an oil pan heater. That being said, it seems like a lot of work to be able to run the thicker oil.
Old Mar 16, 2012 | 12:09 AM
airbrush1's Avatar
airbrush1
Fwiw, the paperwork that came with my 427 build from LPE suggests 15-50... Ymmv
Old Mar 16, 2012 | 07:30 AM
AU N EGL's Avatar
AU N EGL
Hell that is all I use.
In temps below 40 that oil just does not warm up enough ( above 180* ) Oil should get above 200-230 to really be beneficial.
Old Mar 16, 2012 | 07:32 AM
AU N EGL's Avatar
AU N EGL
Greg
greg is correct
For track use, 5-w30 is just too thin and does not take heat well.
that IS the reason for the 15-50 oil
Old Mar 16, 2012 | 07:48 AM
Mike94ZLT1's Avatar
Mike94ZLT1
I run Redline 10w40 here in Michigan!
Old Mar 16, 2012 | 09:00 AM
Quicksilver Vert 01
Good down to 0 degrees F.
Old Mar 16, 2012 | 09:20 AM
yooper's Avatar
yooper
5w30 street application with cats
15w50 road race application w/o cats
Old Mar 16, 2012 | 12:44 PM
  #33
cliff_ford's Avatar
cliff_ford
Reading a recent thread by the OP it would appear that the goal is to reduce piston slap. Will thicker oil do that?
Old Mar 16, 2012 | 12:57 PM
  #34
lionelhutz's Avatar
lionelhutz
You beat me to this very good point. We have no idea why the OP would want to do it or his normal or expected usage for this car, and yet there are lots of opinions given on how good a plan this might be...
Old Mar 16, 2012 | 01:49 PM
  #35
Quicksilver Vert 01
Thicker oil won't make any noticeable difference at all. Period!
Like I said in the other thread, the piston skirt area receives no pressurized lubrication. It only gets a very minimal amount of oil splash from the bottom end, not enough to have any effect on the slap.
Old Mar 16, 2012 | 01:59 PM
  #36
04blackice's Avatar
04blackice
I use gear oil.for some reason my car wont start anymore.i hope its not bexouse i buy arco gas and mix it with water.i really thought 50 octane would be fine..help
Old Mar 16, 2012 | 02:24 PM
  #37
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
10W30 here and if I were to track the car I would go to 10W40
To 15w50 oil who's using it here
Old Mar 16, 2012 | 07:33 PM
  #38
540 vette's Avatar
540 vette
No the OP dosen't think it would reduce piston slap the op was just curious. And wanted to see if the op could use a thicker oil during the summer months. And what oils other people were using.
Old Mar 16, 2012 | 08:02 PM
  #39
Z06supercharged's Avatar
Z06supercharged
Its only a Vette so you go down to 7-11 and buy whatever oil they have on sale and throw it in whatever weight it is. Dont ask on here or do a search cause 7-11 has been around a lot longer than most people on here and they know what they are selling...
Old Mar 16, 2012 | 08:14 PM
  #40
Bakerking31's Avatar
Bakerking31
very sound logic there
