tires
http://www.miata.net/garage/tirecalc.html
You might want to consider trying to stay as close to possible to the oem tires OD to avoid traction control and active handling issues. That will also reduce speedometer error. The C5 obviously came from the factory with a "staggered" difference in OD from front to rear.
For the track it's my understanding its not as much of an issue if you turn traction control and active handling off. I don't race my car so when I recently changed from 17/18" to 18/19", I made sure the OD of the new tires (265/35-18" and 305/30-19") was almost exactly the same OD as oem.
