codes what does then mean
Old Mar 19, 2012 | 12:24 AM
chance voyles's Avatar
chance voyles
3rd Gear
Default codes what does then mean
DTC P1571 Traction Control Torque Request Circuit
DTC P1431 Fuel Level Sensor 2 Performance
DTC P1416 Secondary Air Injection (AIR) System Bank 2
Ok, I just purchased my first c5 I drive it from Mmephis to Jackson, Ms, everything was fine I drive to taco bell to get my wife and I dinner and the car dies in the middle of the road... Above are the codes im getting, i had the car towed home... I'm frustrated because I've only had the car 2 days. Any help would be great! thanks in advance btw the car is a 1998 MINT COND. around 130k miles mostly highway
Old Mar 19, 2012 | 12:25 PM
BigGun's Avatar
BigGun
None of those codes will cause your car to die, UNLESS you are out of gas. DTC P1431 Fuel Level Sensor 2 Performance
Old Mar 19, 2012 | 12:29 PM
chance voyles
3rd Gear
I filled the car up right before I went to get food. It will start for 5 seconds then sputter and die. Almost sounds like it's flooding out.
Old Mar 20, 2012 | 01:51 PM
BigGun's Avatar
BigGun
Or not getting enough fuel. Do you know how to check fuel pressure? On the fuel rail there is a schrader type valve you connect a pressure guage to and turn the key on. Pressure should be very close to 58-60 psi. The fuel pump will not throw a code and will definitively cause the problem you are seeing. Could be other things but i would start here.
To codes what does then mean
