130mph wheel balancer with wheels on the car!!!! Perfect
Apples to oranges.???
I agree with Alan that a very good off the car balancer is usually all that's necessary. I would like to clarify what I meant by 'problematic' suspensions. And I will admit that my experience may be out of date. Some cars, particularly strut suspensions can still exhibit shake even though the tires and wheels are round and balanced. Porsche (sorry) 911s and 944s were notorious for this. Balancing the whole front suspension takes care of that weird 60-65 mph shimmy. I will amend my original post by saying that there are times when spin balancing will solve balance problems that off the car balancing won't cure. At least that's my experience.
Regards,
Garibaldi
Regards,
Garibaldi
I always thought vehicle manufacturers balance their tires on the car....but everything is new, round and tight to begin with. I'm worried that a substantial amount of weight might be needed to "fix" a front end vibration because of a bad hub or rotating assembly but once you rotate that tire it is going to be way off balance in its new location. Any thoughts or experience regarding this?
Thanks,
George
Received 19,307 Likes
'20-'21-'22-'23-'24
I remember in the early 70s watching a tire tech balance wheels using something similar. There was an attachment placed on the face of the wheel and he would touch some rings that would somehow tell him how much weight and where the weights should be placed. Never fully understood exactly how it worked, but he could get the tires balanced perfectly.
Wheel Assume Balance
1/4 mile/AutoX
There were 4 chrome wheels. One to increase weight, one to subtract weight, one to move the weight left and the last to move the weight right. By gently touching the wheels while the tire was spinning you could move the correct amount of weight to the correct location and all the vibration would suddenly stop. There was a small plastic window that showed the amount and location for the weight. Normally you would put half the weight on each side of the rim to prevent dynamic unbalance. This might seem low tech today but it balanced everything, rim, tire, hub and drum/rotor. Not even the mighty Hunter GSP9700 (today's best) can do that.
I worked for a tire shop in 1972 that did the spin balance on the car but no strobe light was used. I only tried it a couple of times while there and can't say I really got the hang of it and it took me longer to get it right than the older techs. The shop also had a tire truing machine that blew my mind at the time. People would come in and buy a new set of tires and then we would put them on the machine and start shaving off rubber. One customer who just bought a new 72 Lincoln brought it in and we shaved his tires too, he swore it was the best ride you could get. I,m thinking the equipment was Hunter brand not sure about it though.
Ha, that brings back memories. The old bias ply tires we're the roundest thing back then....tires have come a long way. I remember there was a tire truer that a lot of servicemen use to take their tires to back in the 70's on Travis AFB. Tons of rubber shaved away on a brand new tire but they swore the tire wore longer and was much smoother than before the tire shaving.
