quick connect transmission cooler lines??
Old Mar 23, 2012 | 11:10 AM
2fas2c's Avatar
2fas2c
Default quick connect transmission cooler lines??
Hi guys!
I am hoping one of you knowledgeable, members here may be able to tell me whether a 03' w/ AUTO originally came from the factory with quick disconnect trans cooler lines?
Thanks in Advance! Bring on the good weather!!!
Old Mar 23, 2012 | 12:46 PM
2fas2c's Avatar
2fas2c
no one knows? I tried Google and got nothing, Google! why have you failed me
Old Mar 23, 2012 | 02:28 PM
RonSSNova's Avatar
RonSSNova
What do you mean by quick disconnect?
I know mine has couplings in them right at the rear of the engine.
2000 coupe.
Ron
Old Mar 25, 2012 | 02:08 AM
2fas2c's Avatar
2fas2c
here is an example of a quick disconnect fitting
Old Mar 25, 2012 | 01:25 PM
RonSSNova's Avatar
RonSSNova
Ah, like the fuel line.
My 2000 is not that way. There are bolt together unions in the lines.
Old Mar 26, 2012 | 12:24 AM
2fas2c's Avatar
2fas2c
awesome thanks, I didn't think so, that really saved me a ton of headache.
Old Dec 12, 2022 | 07:31 PM
Chgr340's Avatar
Chgr340
1st Gear
Originally Posted by 2fas2c
Hi guys!
I know 2001 C5s have QD connections to connect the trans cooling lines to the radiator. The ones on my vette can be removed by using a wrench and unscrewing them or by using a tool to expand the locking clip and pulling the cooling line out of the fitting.
To quick connect transmission cooler lines??
