Muffler Installation Q
Old Mar 24, 2012 | 11:23 AM
flynhi's Avatar
flynhi
Default Muffler Installation Q
I am preparing to install a set of TI muffs on my 99. Given the dimensions of the over the axle, upside down "U" exhaust pipe and the muff itself, is it possible to change this out in the driveway on jacks or do I need to put the Vette on a repair shop lift to get more clearance for the muff and U pipe assembly?
Your experience, pls.
Old Mar 24, 2012 | 11:31 AM
87SAM's Avatar
87SAM
You have to get the rear end way way up in the air, 30 some inches. I did it with jackstands and I was a fool. If you don’t have access to a lift, let a shop do it.
Old Mar 24, 2012 | 12:23 PM
jrose7004's Avatar
jrose7004
It's really tough to do without a lift.
Old Mar 24, 2012 | 12:37 PM
flynhi's Avatar
flynhi
Thanks, fellas. I'll go to a shop
Old Mar 24, 2012 | 05:36 PM
sjbrothers's Avatar
sjbrothers
a sawzall will also work. If you are not going to reuse the old pipes.
Old Mar 24, 2012 | 05:47 PM
baxsom's Avatar
baxsom
i did my ti's in the garage. it was not pretty. had the 4 jackstands up on stacks of 2x10s. take the rear swaybar down and it will help clear a lot as well. if i had it to do over again a lift would be a must
Old Mar 24, 2012 | 08:06 PM
m6 c5's Avatar
m6 c5
Thats works if you are going to install an aftermarket set but he is installing factory mufflers...
Old Mar 24, 2012 | 08:07 PM
m6 c5's Avatar
m6 c5
Oh and here is a picture of when I took mine off my car the first time, I put it on a lifter the other three or four times Ive done it.
Old Mar 24, 2012 | 09:58 PM
DIXZ's Avatar
DIXZ
Yes it is possible! Be very careful! My heart was in my throat the whole time. I wish I had rented a lift.
Old Mar 25, 2012 | 08:50 PM
craig04c5's Avatar
craig04c5
I have to agree. In retrospect it was to risky. I would take it to a shop. Could not take but 3/4 of an hour at most.
Old Mar 25, 2012 | 09:05 PM
Vicarious.'s Avatar
Vicarious.
I was able to get my B&B catback off very easily at 30" on jacks in my garage.
But I wasn't able to get the 1 piece Ti catback over my rear axle without getting it on a lift. It just didn't fit in there with the rear suspension compressed on the jacks. Maybe I did something wrong, but I spent a couple hours trying to get it in there with no luck.
Old Mar 25, 2012 | 09:32 PM
m6 c5's Avatar
m6 c5
Did you drop your rear sway bar? And you would likely need a little more than 30" to get them in.
Old Mar 25, 2012 | 10:11 PM
Vicarious.'s Avatar
Vicarious.
I did yes, but I forgot to mention...I am dropped at least 2" or lower. That might be why I couldn't get it.
Old Mar 25, 2012 | 10:15 PM
m6 c5's Avatar
m6 c5
When your car is jacked up in the air your suspension should be unloaded and dropped down just as far as it would if it was not lowered. As you can see in my picture earlier I was able to fit a yard stick under there and needed every bit of the space as I had to scrape the mufflers on the ground to get them out...
Old Mar 25, 2012 | 10:19 PM
m6 c5's Avatar
m6 c5
And now that I think about it the only thing that affects clearance is the sway bar, ride height or suspension being loaded or unloaded doesnt affect it. Ive done it both ways.
Old Mar 25, 2012 | 10:23 PM
Vicarious.'s Avatar
Vicarious.
In my case, it wasn't that I didn't have the space to turn the muffler flange, I had it high enough to spin the flange in a 360* motion. I think I actually had the car 36" off the ground. I tried every angle, the Ti just wouldn't fit over the axle without bumping into the floor of the trunk.
I am going to go to a muffler shop some day this week to see if they can get it on a lift.
By the way, if you take it to a muffler shop, do they still have to drop the sway bar even though it's on a lift?
Old Mar 25, 2012 | 10:28 PM
m6 c5's Avatar
m6 c5
Its very trick the first time you do it, after that it becomes progressively easier. It is pretty difficult to explain it with out actually showing someone. If I remember correctly though you will want to swing the muffler section to the outside of the car and have it directly under the car right behind the tire and it should slip over the axle.
To Muffler Installation Q
Old Mar 25, 2012 | 11:20 PM
LS1 REDBIRD's Avatar
LS1 REDBIRD
I backed the car into a loading dock at work. Had a friend guide me so I would not go over. Chalked the front tires and went to work!
Old Mar 26, 2012 | 01:14 AM
flynhi's Avatar
flynhi
Does anyone have a part number for the flange gasket needed to install the TI muffs and tailpipe?
Old Mar 26, 2012 | 08:00 AM
m6 c5's Avatar
m6 c5
You should be able to reuse the one that is on there, Ive had mine off at least 5 times and am still using the factory gasket without any problems.
