HELP!!Service Traction Control/Reduced Engine Power Message
Old Mar 27, 2012 | 05:06 PM
Demon98's Avatar
Demon98
Default HELP!!Service Traction Control/Reduced Engine Power Message
I've got this message twice since I got the car 7 months ago. First time, I got the message and the car turned off, but when I started it again everything was normal. Recently, when it rained the message came on again and the check engine light came on. I turned the car off and on, the light came off afterwards. The performance is the same, no problems or noises. Can someone tell me if this message is normal? Should I act on it? Or is it something minor that happens?
Old Mar 27, 2012 | 09:54 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Originally Posted by 8VETTE7
Pull and post your codes including the H or C or HC that follows the 5 position codes. Post ALL of the codes:
http://www.c5forum.com/ayc/dtcdic.php
then get back to us ASAP - (maybe a 1515 or 1514 code in there)
My buddy is having similar issues on hid 2004 MN6 Z06
Thanks,Matt
