19x10 +56 Rear
Old Mar 27, 2012 | 08:51 PM
wilson34's Avatar
wilson34
Default 19x10 +56 Rear
Will these rear wheels fit my stock body with no spacers correctly?
Old Mar 30, 2012 | 11:13 PM
wilson34's Avatar
wilson34
Anyone..
Old Mar 30, 2012 | 11:19 PM
Lothar34's Avatar
Lothar34
Well not if you put a 295/75 tire on them.
They will stick out a little bit further than stock, but just a few mms. Should be fine with the right tire.
Old Mar 31, 2012 | 01:34 AM
Lothar34's Avatar
Lothar34
Originally Posted by 8VETTE7
I disagree with the above post. The 19x10 +56 wheels will be fine.
The Factory C5Z06 wheels are 18x10.5 +58 and they fit the C5 perfectly.
He doesn't have a Z06. Compared to the base OEM wheels, the 19x10 et56 would stick out. 15mm according to that calculator you just posted.
Old Mar 31, 2012 | 09:58 AM
wilson34's Avatar
wilson34
Doesn't matter if he has a Z06 or not. Z06 rear wheels fit all C5's the same, namely nearly flush to the fenders. I use them as the base for comparison for that reason. C5 Coup and Vert OEM rear wheels are sunk well into the fenders on the rear. Check any C5 with the OEM Coup or Vert wheels. OP asked if they would stick out and I interpret that to be "BEYOND THE FENDERS" . The specs he provided will be just over 1/8" MORE inside the fenders than will the factory Z06 wheels.
Thanks, I used a calculator similar to the one you posted with Z06 specs and saw the 4mm further inboard the wheel will sit.
Just wanted to get a second opinion to make sure I wasn't going crazy and seeing things.
To 19x10 +56 Rear
