Oil pressure sensor, again
Old Mar 27, 2012 | 09:16 PM
rayz1951's Avatar
rayz1951
Default Oil pressure sensor, again
I had the oil pressure sensor replaced on my c5 and it failed after 1 week. I took it to a local wrench, whom I trust, to do the job so I,m sure he'll stand behind his work and replace it again. He replaced it with a OEM part the first time but after reading more about it the Standard Motor Prod. PS-308 seems to be the way to go. Is this the best replacement part or is there one better, where can I get it?
BTW the guage spikes way over and the elec. display shows 130 psi, just like last time. The motor runs fine, 50,000 miles, no other issues.
Ray Z
Old Mar 27, 2012 | 09:56 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
It seems to be - the brass ones seem to hold up better!
Thanks,Mat
Old Mar 28, 2012 | 05:57 AM
dougbfresh's Avatar
dougbfresh
Get a relocation kit this time.
Old Mar 28, 2012 | 07:09 AM
droptopC5vette's Avatar
droptopC5vette
MS Events Coordinator
I've been told the cheap ones f advance auto are waaaayyy better than OEM!!!
Old Mar 28, 2012 | 07:19 AM
runner140*'s Avatar
runner140*
Old Mar 28, 2012 | 01:35 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
I would use a brass sensor made by BWD. The P/N is: S4202 at Advance Auto Parts.
Old Mar 29, 2012 | 08:19 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree with using the replacement brass sender as opposed to GM. After a 2nd failure of mine, I went with a PS-308 and although not brass, I also relocated it. Its been just fine.
Old Mar 29, 2012 | 01:36 PM
rayz1951's Avatar
rayz1951
I'm bringing it back next week to replace the new sensor. The mech. spoke to a local Chev. service dept. about it and they suggested replacement of the connector. He said the pins are so small, therefor fragile, they may have been damaged someway. That's what they found out from past experience. Since they have to replace it they might as well replace the connector too. I will purchase the brass sensor for them to install.
To Oil pressure sensor, again
