TTS Header Install
Old May 17, 2002 | 08:14 PM
wickedvette's Avatar
wickedvette
Cruise-In II Veteran
Cruise-In III Veteran
Default TTS Header Install
Just got a set of TTS L/T headers for my 99 coupe. How much clearance is needed from below to do the install? Can it be done with jacks/jack stands/ramps?
Also, how major is the installation and how long did it take?
Old May 17, 2002 | 08:44 PM
Snake Slayer's Avatar
Snake Slayer
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: TTS Header Install (wickedvette)
I was able to Install my TPIS from ramps and jackstands. Not sure on the install time on the TTS headers, I would say allow 4-5 hours !!!
Good Luck
[Modified by Snake Slayer, 7:45 PM 5/17/2002]
[Modified by Snake Slayer, 7:46 PM 5/17/2002]
Old May 17, 2002 | 09:37 PM
TRR's Avatar
TRR
I'm having my TTS LTs installed next week. From what I have heard they are a little harder to install then other headers.
MRR
Old May 17, 2002 | 09:47 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
It may be possible, but I am sure a lift will be much much easier. You must loosen one rear motor mount bolt on the passenger side and raise the motor about one inch.
Old May 18, 2002 | 12:23 AM
wickedvette
ttt
Old May 18, 2002 | 04:33 AM
C5 YA's Avatar
C5 YA
Mine were installed from the top. Not the bottom.
Old May 18, 2002 | 02:10 PM
ToplessTexan's Avatar
ToplessTexan
FYI: http://forums.corvetteforum.com/zerothread?id=290573
:cheers:
Old May 18, 2002 | 08:52 PM
wickedvette
Default Re: TTS Header Install (ToplessTexan)
ttt
Old May 18, 2002 | 09:12 PM
wickedvette
OK - We have the engine raised, valve covers off, coli packs off, battery out and have tried shifting the starter......still no go to get the TTS's in fron the top on the passenger side. We have scoped out putting in from the bottom but its looks even more hopeless.
Any suggestions????
Old May 18, 2002 | 10:01 PM
ToplessTexan
Where are you hanging up?
Old May 18, 2002 | 10:17 PM
C5Noir's Avatar
C5Noir
You have to remove the starter and the three wires holding on it. TTS are a PAIN to install. Add on an extra 3 hours to install them compared to all the other headers due to the misc things you have to remove. Get the starter out and jack the motor up and it'll come out from the top. Barely.
Old May 18, 2002 | 10:24 PM
wickedvette
Default Re: TTS Header Install (C5Noir)
C5Noir -
Thanks, just read your message and 10 minutes before we decided as a last resort to drop the starter......and the header dropped right in!!!!
You're right...pain in the **** on the passenger side....now onto the drivers side!!! :seeya
Old May 18, 2002 | 10:30 PM
C5Noir's Avatar
C5Noir
Remove the steering shaft and oil filter on passenger side and jacke the motor up, remove valve covers, also, it'll go in easier than the passenger.
ToplessTexan
Dude, how slow do you work? :jester
Old May 18, 2002 | 11:45 PM
wickedvette
We're making progress.....how about reinstalling the oil dipstick tube...does it need to be bent to fit the new install?
Old May 18, 2002 | 11:58 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Yes the tube must be bent!
I received a set of installatiom instruction with the TTS Headers, did your supplier not give you a set, that would have made the installation much easier!
If not blame your supplier! If you need a set, email me!
[Modified by wallstAL, 8:00 PM 5/18/2002]
Old May 19, 2002 | 12:01 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I received a set of installatiom instruction with the TTS Headers, did your suppier not give you a set, that would have made the installation much easier!
If not blame your supplier! If you need a set email me!
To TTS Header Install
