Heads/Cam Pass header is HOT driver side is normal
Hi,
I just fired up my AI 243 headed SNL v4 cammed Z06. I adjusted the fuel injector scaling, base idle airflow, startup airflow to get it to run. The passenger side header is SO much hotter than driver side. What could cause this? combustion in exhaust? Help??
Pulled a new spark plug, its black
UPDATE: The ground on the driver side head was broken, causing the driver side not to fire properly. Thus when I compared sides it appeared the passenger side was hotter. Not my brightest moment. The code confirmed it was the driver side, fixed ground today and no more issues.
