Cam Size
Old Mar 31, 2012 | 06:29 PM
Big Gunz's Avatar
Big Gunz
Speedmon, it just hit 55,000 miles on it. As far as speeding, I had one ticket in my life (stupid mistake they threw out) and dont drive fast. I agree with you as 0-100 is all I need. Ok Maybe 0-130! If I can upgrade for 900.00 more dollars for the rear end, its getting done! And since we are in the back of the car with the rest of it, I will check first thing in the am on this as you sold me. Thanks for the advice you are giving me, I appreciate it.
Old Mar 31, 2012 | 07:15 PM
speedmon's Avatar
speedmon
Here's a guy on Youtube....
Claims to be stock with headers and a Z06 rear end.... 11.9
He's also pertty big.
http://www.youtube.com/watch?v=sb-AO...EcKJzDQIzIdHA=
Old Mar 31, 2012 | 08:15 PM
Big Gunz's Avatar
Big Gunz
Well, we shall see as if its 900.00 or less then I will throw in the gears. Once this is done in about two weeks I will take it to the local track and run it a couple times as I never did that before but what the heck! Thanks, M
Old Mar 31, 2012 | 08:53 PM
alj357's Avatar
alj357
Originally Posted by speedmon
Thats a cool formula....
Also C5s have a sticker on the back of the diff that tells you the gears inside......if someone hasn't pulled it off.
How many miles on your 99?
Have fun......
Both good ideas, you can also look inside your glove box and if you have 2.73 the code would be GU2. I can't recall the code for 3.15's.
Al
Old Apr 1, 2012 | 04:05 AM
Big Gunz's Avatar
Big Gunz
Thanks alj, I just looked at the codes on a page and you are right. GU2 is 2.73, GU6 is 3.42 and G90 is a 3.15. Bottom line is this would be an upgrade that I never thought of that would give me some great bang for the bucks. Thanks again all as today the cover comes off and she starts her 2nd phase. Once I am done in two weeks I will let you all know how she did hp wise and run a quarter a few times to see.
:flaghalfmas t:
Old Apr 1, 2012 | 04:49 PM
mitchell c's Avatar
mitchell c
Al
The code for 3.15 is G92. But you have to assume the gears were not changed by a prior owner.
Old Apr 1, 2012 | 06:20 PM
Big Gunz's Avatar
Big Gunz
I have the G-90, so I assume they are 3.15's? Car went into the shop this afternoon so we are thinking around 385 for hp, we shall see. Thanks all as I will let you all know how it works out. We are going to stay wth the stock rear for now and the only work outside of the engine will be a 3600 Yank converter with cooler.
