BCM change and dealer programming?
Old Mar 31, 2012 | 11:54 AM
minitech's Avatar
minitech
Default BCM change and dealer programming?
For a BCM change I know the dealer needs to program it for it to work. What exactly are they programming? Is it so the VATS will work? Anything more than the security stuff?
Old Mar 31, 2012 | 08:32 PM
minitech's Avatar
minitech
Thanks 8Vette7
My tuner said he could turn off the security options through the tuning software, wasn't sure what else it needed.
Old Apr 1, 2012 | 06:25 AM
dougbfresh's Avatar
dougbfresh
They program all the options the car was built with.
Old Apr 13, 2012 | 01:10 AM
piran21's Avatar
piran21
If a new BCM is installed and the PCM/BCM relearn procedure is completed, the car starts and runs fine. The key FOB works. However there are some strange things happening. The power seat switch controls the telescoping wheel. Does this get resolved after the BCM is programmed with the RPO's are completed with the Tech 2?
Old Apr 13, 2012 | 09:40 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The SCM controls the telescoping steering wheel but yes, the car's systems and programming needs to know that its there.
To BCM change and dealer programming?
