Whistling noise during acceleration.
Old May 18, 2002 | 02:23 AM
DeetchC5's Avatar
DeetchC5
Default Whistling noise during acceleration.
Whenever I step on the gas I hear a short whistling noise. Sounds like it's coming from the front driver's side area. Can't figure out what the heck it is. Any ideas? Belt, normal LS1 intake whistle, or maybe my imagination? Whatever it is, it's bugging the crap out of me.
Deetch
Old May 18, 2002 | 05:07 PM
alc2001's Avatar
alc2001
Default Re: Whistling noise during acceleration. (DeetchC5)
Deetch -
Mine makes a very high pitched whistling noise when the throttle is around 10 percent position. It is very sensitive to throttle position. I have assumed it is from air flow through throttle area. But who knows? Also I didn't notice any change after replacing stock filter with a Blackwing.
Alan
Old May 18, 2002 | 09:35 PM
DeetchC5's Avatar
DeetchC5
Default Re: Whistling noise during acceleration. (alc2001)
Assuming that's the issue, which it sounds like it is, does anyone know if there is a remedy for this?
Deetch
Old May 18, 2002 | 09:59 PM
robiferretti's Avatar
robiferretti
if you have an aftermarket sound system it can be line noise dur to the amp turned up too high, or wires too close to each other, or no ground wire :cheers: , as far as i konw could also be alternator whine :confused:
Old May 18, 2002 | 10:19 PM
VERTVETTE's Avatar
VERTVETTE
Default Re: Whistling noise during acceleration. (robiferretti)
So do I :confused: J/K I agree with robiferretti :yesnod:
Old May 18, 2002 | 10:30 PM
Vet-Y2K's Avatar
Vet-Y2K
alc2001 are you getting this whistling noise right at 2200rpm to 2300 rpm steady throttle or even on light decel?
The reason I ask is mine does it right in that rpm range if I'm crusing steady on the hightway. But goes away the minute I touch the throttle. Just past 10%. 15% or more and no noise? Maybe throttle body whistle? Anyone else?
:rolleyes: :confused:
Old May 19, 2002 | 01:27 PM
Flintstone's Avatar
Flintstone
Default Re: Whistling noise during acceleration. (Vet-Y2K)
Sounds like intake manifold whistle.
Mine will do it on light acceleration at ~ 1600 RPM, with a few lighter harmonics.
As far as I can tell, it's not hurting anything, just annoying. There is a TSB out there for it, and they replace the intake manifold.
F
Old May 19, 2002 | 01:47 PM
DeetchC5's Avatar
DeetchC5
Default Re: Whistling noise during acceleration. (Flintstone)
Any way to convince them that installing an LS6 Intake Manifold would fix the problem? :lol:
Deetch
Old May 19, 2002 | 09:58 PM
robsvette's Avatar
robsvette
are you the 2nd owner? maybe you have a LPE twin turbo!!! :eek:
Old May 19, 2002 | 11:14 PM
RCswish's Avatar
RCswish
Default Re: Whistling noise during acceleration. (robsvette)
Exactly what I was thinking. You think there are honest people in the world then this....you buy the car and they don't tell you about the LPE twin turbo. I hate it when that happens. :D
Old May 20, 2002 | 01:14 AM
alc2001's Avatar
alc2001
Vet-Y2K,
You described it exactly. Not much on deceleration though.
Old May 20, 2002 | 01:22 AM
Gandalf's Avatar
Gandalf
Where can one get a copy of the TSB for the intake ?
Old May 20, 2002 | 01:50 AM
alc2001's Avatar
alc2001
Default Re: Whistling noise during acceleration. (Gandalf)
Here is the TSB from the GM service web site:
32. #A001582A 5.7 LS1 LS6 Engine Whistle Type Noise Off Idle to 2000 RPM - DRIVEABILITY RESONANCE THROTTLE A001582A SUPERSEDES A001582
When you click on it this is what you get:
Information Not Available
The information associated with this title is Preliminary Information and may not have been validated
by GM for accuracy and effectiveness. For further information, non-GM dealers call 1-800-260-9377.
GM Dealers contact GM Technical Assistance
at the number you have been provided.
Can anyone access this TSB?
Old May 20, 2002 | 11:47 AM
Mark S.'s Avatar
Mark S.
The "dreaded" whistle only applies to the '01 model. GM redesigned the intake plenum when it brought out the Z06. It used the same plenum on the coupes and convertibles. There is an indentation/pocket in the plenum right where the throttlebody is mates to the plenum. As the air rushes in and your RPM is somewhere between 2,100 to 2,400 RPM you will hear a whistle (worse when the outside air temp is colder). Some cars whistle louder than others. Sometimes you get lucky and the whistle is barely noticeable. I hear mine "whistle" only when the temp drops below 45 degrees outside. Other than that, I never hear it. Turn up your stereo and it's practically gone. When the '02 came out GM had fixed the intake plenum problem. It's my understanding that if the "whistle" is really driving you crazy, that there is a TSB which allow you to have the plenum replaced.
MN6's (like mine) can sustain the whistle by just putting into that RPM range and holding it there (most '01 automatics only hear it momentarily since their overdrive will drop it below 2,000RPM for most driving).
To Whistling noise during acceleration.
