Axle nut
Old Mar 31, 2012 | 11:17 PM
skydive120's Avatar
skydive120
Default Axle nut
Trying to change out a wheel bearing and the right back axle nut will not break loose even with a good soaking and breaker bar.....
Heat?
Thanks--
Chris
Old Mar 31, 2012 | 11:31 PM
BigGun's Avatar
BigGun
Heat?
Thanks--
Chris
Longer breaker bar. You have plenty of room.
ZedO6's Avatar
ZedO6
Heat?
Thanks--
Chris
Longer pipe on the breaker bar...make sure the car is on the ground and you are using the brakes to keep the wheel from turning. Otherwise you are working the crap out of the axle joints to try to loosen it.
Old Mar 31, 2012 | 11:46 PM
1986coupe's Avatar
1986coupe
Oil, heat, and the best way is with a pneumatic impact driver.
To Axle nut
