Iphone 4 install for c5
Old Apr 2, 2012 | 01:09 PM
machfive98's Avatar
machfive98
Default Iphone 4 install for c5
does anyone have info for installing a device that will play music off my iphone, allowing me to use stock radio controls? Thanks...
Old Apr 2, 2012 | 01:40 PM
dougbfresh's Avatar
dougbfresh
Plenty of threads on installing Ipods here-try SEARCH!
Old Apr 2, 2012 | 02:25 PM
MotoMike02's Avatar
MotoMike02
Old Apr 2, 2012 | 03:13 PM
machfive98's Avatar
machfive98
yes, I have used the search and read the posts, however I was hoping that I might get some input from someone new, or maybe some fresher information. All the same... thanks for your help.
Old Jun 5, 2013 | 06:52 PM
ibfuelish's Avatar
ibfuelish
More importantly is installing one in a C5 that is prior to 2003. There is a huge difference. My 2002 doesn't have a Band button, so some of the plug in solutions don't work. I figure without the CD changer, there's no way to access the three wires everybody is posting about.
That being said....What the hell is the AUX button for?
Old Jun 5, 2013 | 11:30 PM
Z06_YOLO's Avatar
Z06_YOLO
Cruising
I just wired mine up earlier this week. I followed the write up in this threadhttp://ls1tech.com/forums/stereo-ele...t-adapter.html
It works very well, although the only control you have from your factory radio is volume. Changing song or going through playlists is still done through the phone. I think there are plug in adapters you can get for like $100, but i liked the $5 cost of this method. Not sure if the plug in adapters give you any more control though; all the once I have seen appear to only be stereo jacks which doesn't transfer the control like the usb cable.
Old Jun 6, 2013 | 01:12 AM
Rookieracer's Avatar
Rookieracer
Here is a link to one I did. I'm happy to answer any questions you may have.
http://forums.corvetteforum.com/audi...head-unit.html
Old Jun 6, 2013 | 02:24 PM
tlove32's Avatar
tlove32
If you have a cd changer - this is what you need:
http://shop.doubledmods.com/Peripher...PXDPPXHGM2.htm
If you DO NOT have a cd changer - this is what you need:
http://shop.doubledmods.com/Peripher...PXDPPXHGM4.htm
To Iphone 4 install for c5
