dieing when at stop..
Old Apr 2, 2012 | 03:17 PM
sccs's Avatar
sccs
Default dieing when at stop..
This is so f'ed up i can't belive.. i took off coil packs and disconected em to clean the valve cover easyer.. only on one side..after first run.. everything was fine.. then i was turning at my garage(and there is alot of reverse and first gear to get out-back and forward, back and forward etc.) now it sometime dropes when i step on brakes to lower then 500 rpm and everything quiet for 1-2 secounds and then 'whooom' back to rpm..
I noticed this before but never droped rpm so low..
what the hell..
Old Apr 2, 2012 | 04:02 PM
dougbfresh's Avatar
dougbfresh
Bet you have a flashing CEL and codes too.
Old Apr 2, 2012 | 04:10 PM
Turbopower87's Avatar
Turbopower87
Maybe you nudged a vacuum line while you were in there?
Old Apr 2, 2012 | 04:26 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Should also look at the pcv connection tube to the intake. The grounds for the coil packs are on the rear of the driver's side head but you should have a code(s) if its lose.
To dieing when at stop..
