Correct Idle RPM
Old Apr 3, 2012 | 06:48 PM
Jumper11's Avatar
Jumper11
Default Correct Idle RPM
I got a 2002 LS1 with K&N filters and borla exhaust. My RPM usually is 800 at idle but sometime flutuates +/- 100. I believe the engine is stock with the exceptions mentioned above. Can you tell me what is the RPM suppose to be (stock). Thanks
Old Apr 3, 2012 | 08:28 PM
m6 c5's Avatar
m6 c5
That is right about where it should be and depending on the temperature it will be a little higher or lower. Also once your car has reached operating temperature the idle should hold steady with a +- 50 variance.
Old Apr 4, 2012 | 07:37 AM
7LitreC5's Avatar
7LitreC5
I bought my 02 coupe new and the stock idle was 800.
To Correct Idle RPM
