What is missing from my radiator?
Old Apr 4, 2012 | 10:37 AM
jsbzoh6's Avatar
jsbzoh6
Default What is missing from my radiator?
I was changing out my outside air temp sensor and noticed a hole in my radiator probably 3" above the drain petcock. It looks like it has threads as if its a bung for something. As far as I know I'm not losing coolant. Is this normal?
Old Apr 4, 2012 | 11:33 AM
byronhunter's Avatar
byronhunter
Transmision Cooler!
Old Apr 4, 2012 | 11:41 AM
jsbzoh6's Avatar
jsbzoh6
I was thinking that myself. My car is a manual, so it won't have the cooler.. but would this be capped, or is it a separate system inside the same radiator?
Old Apr 4, 2012 | 11:58 AM
jimmymc's Avatar
jimmymc
if it is for tranny, then it does not mix with water, how did the factory miss that?
Old Apr 4, 2012 | 01:20 PM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by byronhunter
Transmision Cooler!
Well,......actually you DO "have the cooler", it's just not hooked up.
Separate passageways inside. Same radiator for both cars.
Old Apr 4, 2012 | 01:31 PM
Bill Dearborn's Avatar
Bill Dearborn
If you are not the original owner it may be a PO had the radiator replaced and they used a radiator from an automatic since it was available and a radiator for a manual wasn't available. I notice the lower radiator hose isn't stock so there has been some work done in the area.
Bill
Old Apr 4, 2012 | 01:34 PM
baxsom's Avatar
baxsom
Bill
now the OP is going to be all super paranoid trying to figure out what is up with his car.
Old Apr 4, 2012 | 01:37 PM
jsbzoh6's Avatar
jsbzoh6
Bill
Considering the rest of the things I've had to fix due to the previous owner, my first guess is they purposely put an automatic radiator in just to do the wrong thing.
Either way, as long as it isn't a missing plug or piece. Thanks everyone.
Old Apr 4, 2012 | 01:52 PM
LoneStarFRC
Bill
I considered that as well so out of curiosity I checked. Same GM part number for both cars. I haven't had a stock radiator for a couple years now, but it seems like I recall seeing the same thing on my MM6 car as well.
I agree with you Bill. That area does look rather clean, etc.
Old Apr 4, 2012 | 01:53 PM
LoneStarFRC
To What is missing from my radiator?
