Next Problem: Slight clunking from rear..
Old Aug 4, 2012 | 06:20 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
there is a joint inside the axle boot....it is probably dry.....two options...buy another axle (used is cheaper) replace the boot and grease the existing one
Old Aug 4, 2012 | 08:54 AM
Birdman's Avatar
Birdman
The problem was fixed when I did everything in post #12 everyone. I will get around to greasing that spline at some point I'm sure, but as of now everything is good.
Thanks for all the contributions!
Old Sep 5, 2012 | 03:53 PM
C5FRCPewter's Avatar
C5FRCPewter
Good thread. You described the problem I have. It started shortly after having a clutch installed. I'll tighten all items you did in post #12 tomorrow.
Old Sep 5, 2012 | 07:36 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Make sure you have enough air in your tires and tighten down the spare tire.
It can make a lot of noise.
