damper install Q
Old Apr 7, 2012 | 10:50 PM
jv01's Avatar
jv01
Default damper install Q
http://i262.photobucket.com/albums/i...easurement.jpg
once the two step process is completed does the damper sit flush with the crank shaft .
or does the 2.40 mm gap still remain .
Old Apr 7, 2012 | 11:25 PM
rodsvet's Avatar
rodsvet
The gap remains. Rod
Old Apr 7, 2012 | 11:32 PM
jv01's Avatar
jv01
thanks much rodsvet. jv
Old Apr 8, 2012 | 05:05 PM
Paul 75 L82's Avatar
Paul 75 L82
After I checked the gap I took a 3/4" steel ruler and laid it in the belt track up to the other tracks to make sure they were aligned.
Old Apr 8, 2012 | 05:35 PM
RonSSNova's Avatar
RonSSNova
I measured .130-.140" from the face of the balancer (where the bolt flange hits) to the crank.
These balancers pull on pretty easy, there should be no way it would not seat on the crank gear with 250ft lbs applied to the bolt.
Ron
To damper install Q
