ARE 422 10.86 N/A
Old May 19, 2002 | 01:50 AM
Tom Hall's Avatar
Tom Hall
Default ARE 422 10.86 N/A
I ran a 10.86 @ 125MPH with a 1.53 60ft. with my 28" tall Hoosier Slicks and 110lbs weights in the rear for traction. I took the weight out and lost traction and ran a 11.03 @ 126 mph with a 1.70 60ft. The only changes from last week was I installed the VaraRam.
I went to the track to run some Nitrous, but melted 2 Spark Plugs on the first run. It only ran 10.18 @ 139 MPH. I don't know why the plugs went out, but when I check it out some more, I will let everyone know if it did any damage to the engine. It was one of those Bitter/Sweet days
:rolleyes:
Update, Blown Head Gasket
:mad
[Modified by Tom Hall, 5:47 PM 5/19/2002]
Old May 19, 2002 | 09:00 AM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: ARE 422 10.86 N/A (Tom Hall)
:rolleyes:
[Modified by Tom Hall, 12:57 AM 5/19/2002]
:cheers: I told you last week to add the weight back in your car................. :yesnod: You were sand bagging it again , weren't you????? :lol:
Old May 19, 2002 | 12:06 PM
DJ Self's Avatar
DJ Self
Default Re: ARE 422 10.86 N/A (Mag Red Monster)
NICE....... :yesnod:
Old May 19, 2002 | 12:23 PM
ledfoot's Avatar
ledfoot
Great Times!
David In Indy :seeya
2000 NBM M6-Coupe
All Options minus F45
Euros/Lloyd Mats/Chrome Shifter/Ripper/Halltech tric/T-bypass/Taylor
Wires/TTS Headers/High Flow Cats/X-pipe/Indy Corsas/Baers/Z06
Calipers/Russell ss brake lines/Hawk Pads/Yokohama Avs Sports/Porsche DOT4 Hi-Performance Brake
fluid/Redline oils/Zaino/Engine Dress by Auto Buffs and Design Specialties
Old May 19, 2002 | 12:34 PM
The One's Avatar
The One
:cool: :yesnod: :cheers:
Old May 19, 2002 | 02:30 PM
NineBall's Avatar
NineBall
Congrats Tom! Got any pictures of the C5 with 28" slicks? I've never seen that before! Cool.
Tony :seeya
Old May 19, 2002 | 06:44 PM
Tom Hall's Avatar
Tom Hall
Default Re: ARE 422 10.86 N/A (NineBall)
Tony
I keep forgetting to take pictures of the car with the Hoosiers. I thought maybe someone got a Video of Wade driving my car and running a 9.7 @ 145 mph at the Birthday Bash.
Tom
Old May 19, 2002 | 08:29 PM
Ripped427's Avatar
Ripped427
Congrats Tom! Those are great times, I hope you didn't hurt anything.
Dennis :seeya
Old May 19, 2002 | 08:34 PM
IMXCITD's Avatar
IMXCITD
Default Re: ARE 422 10.86 N/A (Ripped427)
Great numbers!! Congrats! :)
Old May 19, 2002 | 08:52 PM
STEALTH C-5's Avatar
STEALTH C-5
Tom,What was your ET@ MPH before the Vararam,if I remember correctly it was 11.06@123.So you gained two tenths and three Mph with the Vararam and 100LBS additional weight,interesting,were weather conditions similiar?What intake did you have prior to the change?
[Modified by STEALTH C-5, 9:48 PM 5/19/2002]
Old May 19, 2002 | 09:53 PM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Awesome Naturaly aspirated times! :cheers: :cheers: Not to many C5s running into the 10s on motor only and that is one heck of an achievement. Sorry to hear about your N20 Problems and hope the damage is minimal and you are back tearing it up asap.
Nitrovette:D
Old May 19, 2002 | 09:59 PM
Wide Open Throttle's Avatar
Wide Open Throttle
Good numbers :cheers: Sorry to hear about the head gasket, that's part of racing.
Old May 19, 2002 | 10:31 PM
tscales's Avatar
tscales
St. Jude Donor '07
Just to make sure I understand. You went 10.86 just on the motor. I ask for an important reason. Mike Norris is building me a 422, using mostly ARE components.
The difference is that he's adding an ATI Procharger with 12lbs of boost on top of the 422.
Wonder what my times could be?
Tom
who just can't wait :):):)
P.S. Amazing times....congrats
Old May 19, 2002 | 11:06 PM
Tom Hall's Avatar
Tom Hall
Default Re: ARE 422 10.86 N/A (Wide Open Throttle)
Thanks again guys. I thought it was missing on the top end on the last motor run, but didn't think to much about it B/C the numbers were good.
I changed plugs, filled up with Race Fuel and put in the Nitrous program. I autotaped the run and had no KR and only had 1 degree of KR after the 1-2 shift, that's when I felt it starting to misfire a little and when I slowed down I could hear a real bad exhaust leak. Number 5 & 7 plugs had melted the ground off the plugs. I know metal was blown out the exhaust, but what I worry about is what damage it done to the cylinder walls. Valves can be fixed fairly easy, but not the cylinders. I know this is part of Racing, but I thought the Head Gasket problems were solved on this Engine.
Anyhow, I have to find out if I can get the Head off without pulling the Engine. It has Studded head bolts. I have already done a Compression test and Leak Down test and the Gasket is blown out the bottom. No coolant leaks, just Exhaust leaking right out the bottom of the head on those 2 cylinders.
What most likely happened is when the gasket let go, it leaned out those 2 cylinders and burnt up the plugs.
I want everybody to know that I'm not saying anything bad about ARE. Nick and Wade have been Great to me. I'm just sharing my bad Luck with all of you. I will call them in the morning.
Mike, Yes I did pick up 3 mph and 2 tenths with the VaraRam. The weather was about the same. I put the weights in the rear compartments. When the track is bad I leave them in and do better on the 60ft. I know more weight is bad, but if your not hooking, you have nothing to lose and everything to gain. I retired the Mud Sucker and was just running with the twin flow under the hood. I was in the market for a cold air system and liked what I seen in that system.
Tom, yes that is on motor only(10.86). I think with gears and a different Converter I could make a low 10 second car out of it. I don't know what you would run, but everybody is making power, getting it down track is the real challenge. The 6 speed guys are doing great. I just have to point and shoot and hope it goes straight. I do set up my car and tweek on it myself.
Steve, I don't think I can get the parts fast enough to make it to the Cruise In. I was really wanting to go.
[Modified by Tom Hall, 10:16 PM 5/19/2002]
Old May 19, 2002 | 11:09 PM
Steve Row's Avatar
Steve Row
Kicking butt!!
Are you coming to the Cruise-in, Tom? Love to race you again in the brackets. I will need the 2.5 second head start!
So cool. :cheers:
Old May 20, 2002 | 12:26 AM
EuG's Avatar
EuG
Congrats on great times, Tom!
Sorry about the head gasket. Nitrous is scary šhit I gotta say :( :crazy: Hopefully the damage is minimum and it’s a quick fix.
BTW: Interesting that you picked up so much going from twin flow to ram-air setup.
That’s usually the difference people see going from stock to cold-air.
I guess those aftermarket underhood intake systems don’t work that great huh?!
[Modified by EuG, 11:29 PM 5/19/2002]
Old May 20, 2002 | 12:48 AM
my00c5's Avatar
my00c5
Default Re: ARE 422 10.86 N/A (EuG)
:cheers:
To ARE 422 10.86 N/A
Old May 20, 2002 | 02:23 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
Congrats on the runs and hope damage is minimal.
JB
Old May 20, 2002 | 03:07 AM
Sir Sel's Avatar
Sir Sel
Great run. Hope they can fix it fast.
Old May 20, 2002 | 10:45 AM
NoMercy's Avatar
NoMercy
Congrats on an awsome run!! :cheers:
