2002 z door lock problem
Old Apr 12, 2012 | 11:35 PM
bobster42's Avatar
bobster42
Default 2002 z door lock problem
Can anyone help me out .i just bought a 2002 z with 19,000 miles on it and the drivers door lock is not working with key pod or door switch control.anyone have a good idea what's going on,passenger door works!
Old Apr 13, 2012 | 12:25 AM
1986coupe's Avatar
1986coupe
Does it make any noise at all? Open the door up to see if everything is connected properly. Also, look at the power door lock mechanism to make sure that it is ok. See if it is damaged physically. You may have to remove it to test it to make sure it is doing what it should be doing and not jammed up.
Old Apr 13, 2012 | 07:37 AM
bobster42's Avatar
bobster42
It looks like its trying to move but it's not moving far enough to lock it or unlock. It's like it is almost getting stuck or it does not enough power to move it.Is it hard to take the door panel off?
Thanks Bob
Old Apr 13, 2012 | 12:14 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
I have a 02 Zo6 also and the drivers door lock will unlock with the FOB but it will not lock. I changed the relay in the module and I hear it click when activated but it won't lock. I need help too!
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old Apr 13, 2012 | 01:21 PM
bobster42's Avatar
bobster42
i talked to a corvette mechanic at chev dealer and he said need to replace door module 400 bucks.
Old Apr 13, 2012 | 11:16 PM
65GGvert's Avatar
65GGvert
Get a second opinion from a non-dealer Corvette guy. Switch the left and right modules for troubleshooting before you spend $400. As always, your opinion may vary.
Old Apr 14, 2012 | 03:12 AM
skeeters65's Avatar
skeeters65
Bad relay in door module?? Does it not lol and unlock??
Old Apr 14, 2012 | 07:34 PM
zo659's Avatar
zo659
This is a great tip. I did this two weeeks ago and all that needed replacing was a $1.33 relay in my rdcm. This only takes about a hour to fix. If you need a relay, I have extras for free, plus shipping USPS. PM me if you want a couple or any info on this easy repair.
Old Apr 15, 2012 | 06:26 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
After replacing the relay in mine it still didn't work. Bought a used switch assembly and the it worked. But the color was off, so I ended up taking mine carefully apart and found a small open spot on the board in the circuit for the lock switch. I soldered a bridge across the bad spot and problem solved.
Old Apr 15, 2012 | 09:33 AM
RainRider's Avatar
RainRider
Have a similar problem with my passenger door lock, 03 Z.
Doesn't always unlock, just sometimes tries but not complete.
Plan to take it out and send it to absfixer. Saw that he advertises fixing these too.
Old Apr 15, 2012 | 02:12 PM
bobster42's Avatar
bobster42
whats the procedure to get th door panel off?
Old Apr 15, 2012 | 02:27 PM
bobster42's Avatar
bobster42
If I lock it manually it will open with the key pod it just will not lock it does this point to the problem? Thanks
Old Apr 16, 2012 | 12:48 PM
SacCityCorvette
Supporting Vendor
Thats exactly what mine does too!
Old Apr 17, 2012 | 12:07 AM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
Look on the tech forum for door panel removal. It is very easy. The control rod may be hanginig up. The expensive relay last resort. IF YOU NEED A STEP BY STEP PM ME
Old Apr 19, 2012 | 08:53 PM
Greg_E's Avatar
Greg_E
Here is a link to replacing the relay on the door module if that's what it turns out to be.
http://www.ronjpics.com/Corvettestuff.htm#DCM
Old Apr 22, 2012 | 03:39 PM
bobster42's Avatar
bobster42
I replaced the relay and it fixed the problem
Old Apr 22, 2012 | 04:27 PM
bobster42's Avatar
bobster42
Thanks everyone for all your help
Old Jun 21, 2012 | 06:35 PM
FASTFATBOY's Avatar
FASTFATBOY
I have been researching this issue, this seems to be the fix.
http://forums.corvetteforum.com/c5-t...ndow-inop.html
To 2002 z door lock problem
