Servicing Anti Skid
Old Apr 15, 2012 | 12:22 AM
lferington's Avatar
lferington
2nd Gear
Default Servicing Anti Skid
I have a problem that has been happening quite often, the little corvette sliding back and forth light came on and the ABS light came on. The DIC then starting saying Service ABS, Service Active Handing System, and Service Traction Control System. One Tech. recommended I replace the sensor on the steering column, after running the code. He could not say which sensor for sure. Anyone have any other ideas?
Old Apr 15, 2012 | 12:41 AM
Supercharged111's Avatar
Supercharged111
I thought there was only 1 sensor in the column, the steering wheel speed sensor. Hopefully someone can better clarificate. Are you aircraft maintenance by chance? The only time I've ever heard of ABS referred to as anti skid was on aircraft.
Old Apr 15, 2012 | 01:17 AM
98DC231's Avatar
98DC231
Service abs likely means this issue is in your ebcm. Replacing your steering position sensor is not likely to resolve your issue.
What codes are you getting?
To Servicing Anti Skid
