still throwing a code but feeling much more encouraged
Old Apr 15, 2012 | 01:08 PM
Vetteatlast's Avatar
Vetteatlast
Default still throwing a code but feeling much more encouraged
Ive been fighting the whole (checkABS,Check Traction control, Check Stability control light) for a month now and I was getting a 1225 code which is a LF wheel Variation code. So while I was on Forum I Chatted with a forum member that suggested I switch the 2 wheel bearing pigtails and while I was at it , I sprayed the connectors with contact cleaner and I took it for a short ride, I couldnt get it to throw a code until I hit around 80 MPH. So when I got home ,I checked the code and it was a 1226 code this time.I will buy a new pigtail for the right side but one thing I noticed everytime it throws a code is that it also throws 3 code which are U1096,U1064and U1016 which is a loss of communication with, PCM and BCM, does anyone have any idea why Im loosing communication?? Thanx
Old Apr 15, 2012 | 02:06 PM
87SAM's Avatar
87SAM
If they are history comm codes, it may not be a bad thing.
From the service manual:
Condition/Concern:
DTCs U1016, U1064 and U1096 may be present when scrolling through the onboard diagnostics via the instrument cluster Driver Information Center (DIC).
Recommendation/Instructions:
This is a normal software function as long as the DTCs have a history status upon ignition cycling. No repair attempts should be made.
Old Apr 15, 2012 | 02:29 PM
Vetteatlast
Thankyou very much
To still throwing a code but feeling much more encouraged
