Diff removal
Old Apr 18, 2012 | 10:45 AM
Chris C5's Avatar
Chris C5
7th Gear
Default Diff removal
I need to get the diff out of my 99 FRC (snaped the rt side output shaft on stickys at the track) and looked at all the post refering to this subject. Cajundudes info I could not retrive but read a couple posts were you don't have to disconnect T/T from motor. Is this possible with out damaging fire wall or anthing else? I am doing it on floor jacks in my garage. Couldn't find a good write up on this method.
Old Apr 18, 2012 | 10:55 AM
bumble-z's Avatar
bumble-z
You do not have to disconnect the t/tube from the motor or bell housing.
Just lower every thing enough to remove the cradle & then pull the diff., from the tranny
I'll see if I can pm you the Cajundude instructional.
His instructional is what I used, when I pulled mine.
Good luck
Old Apr 18, 2012 | 11:02 AM
Chris C5's Avatar
Chris C5
7th Gear
Thanks. I have the cradle off and tranny on jack, but was afraid to lower it too much, couldn't get it to clear the output from tranny. Did you take off exhaust and tunnel cover?
Old Apr 18, 2012 | 11:41 AM
bumble-z's Avatar
bumble-z
Yes, you must disconnect the coupling from the throttle body to the CAI
( cold air induction)
I have long tubes & I had the t/plate removed & the x pipe off.
Old Apr 18, 2012 | 03:28 PM
Dope's Avatar
Dope
Resident moron
http://home.comcast.net/~dopemaro/C5...ar_install.pdf
Dope
Old Apr 18, 2012 | 04:19 PM
LawdoG247's Avatar
LawdoG247
You don't have to come down as far as you might think. When you have the diff slid back just over 3/4 of the way out, you can pivot it down and off to the side like I did. Do this very carefully to avoid scarring the shaft or ring gear.
As the above posts say, make sure you disconnect the accordion intake tube from the throttle body, plus keep an eye on the clearance between the shifter box on the torque tube and the fuel lines that run on the drivers side of the tunnel underneath it!
Old Apr 18, 2012 | 08:21 PM
Chris C5's Avatar
Chris C5
7th Gear
Thanks guys for the much needed info should be out tomorrow night. Just go home from work.
To Diff removal
