AC compressor oil in a C5
Old Apr 20, 2012 | 12:57 PM
MGK's Avatar
MGK
Default AC compressor oil in a C5
I am evacing, & recharging a 2000 C5 AC system that currently has a low charge. Do I need to add compressor oil and if so which one? Pag? I was going to add 2oz of high viscosity pag with 1 oz of R134a. Thoughts
Old Apr 20, 2012 | 01:40 PM
Lothar34's Avatar
Lothar34
I think you're supposed to measure the oil that comes out and replace it with the same amount.
Old Apr 20, 2012 | 01:46 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
I would say that you're right on the mark with adding 2oz of PAG oil, as long as the rest of the system has remained intact.
Use PAG 150 refrigerant oil. It's very close to the OEM spec GM refrigerant oil already in the system.
Old Apr 20, 2012 | 01:48 PM
Quicksilver Vert 01
That's only if you are REPLACING the A/C compressor.
To AC compressor oil in a C5
