windsheild washer tank
Old Apr 21, 2012 | 11:05 PM
bifs1229's Avatar
bifs1229
5th Gear
Default windsheild washer tank
how difficult or easy is it to replace the tank on a 2004 ?
Old Apr 21, 2012 | 11:22 PM
bumble-z's Avatar
bumble-z
It would be one of the easiest things that you could do.
Really wouldn't need instructions.
Play particular attention to the position of the Hi/lo sensor, located in the rear of the tank, towards the firewall....., when disconnecting & re connecting .
When I had my tank out, I reconnected it 180 degrees off (upside down)
This will cause a Low Coolant message to come up on display.
Good luck, You can do it.
