Tire Pressure
Old Apr 22, 2012 | 02:06 AM
Old Horsepower's Avatar
Old Horsepower
Default Tire Pressure
I have stock tires and rims on my 99. On the door panel it says correct tire pressure is 30 psi front and back. I have been putting in about 33 in the front tires and about 28 in the back tires. Tires seem to be wearing evenly. Does this sound right? Or am I wasting my time and 30 all the way around is just as good? Thanks for any advise.
Old Apr 22, 2012 | 02:17 AM
Zorlac's Avatar
Zorlac
30 all four corners cold.
Old Apr 22, 2012 | 01:11 PM
Old Horsepower
Originally Posted by 8VETTE7
30 cold is a good starting point but I adjust up or down a few pounds to get the best tire wear. If your happy with the tire wear, leave what you have......
Thank you. In my other cars it worked so I was doing the same with Vette. In past if I ran same pressure all around I would get outer wear in front and center wear in rear. Just replaced front tires and 4 wheel alignment, about $900. So I'm trying to get all I can out of them.
Old Apr 23, 2012 | 12:27 PM
ol rich's Avatar
ol rich
I use 32 cold all over. seems fine- no bad things happening yet.
Old Apr 23, 2012 | 12:31 PM
jrose7004's Avatar
jrose7004
I use 30 psi cold just like it says on the door.
Old Apr 23, 2012 | 12:50 PM
lionelhutz's Avatar
lionelhutz
I have 19" all around and I do as you're doing. Start at 30psi and then adjust pressure for best wear. I have >35k miles on my rear PS2's. They are wearing fairly evenly and I run 27psi to 28psi cold in them. They're just getting to the wear bars now.
To Tire Pressure
